Hoover vtc 791nb-80 stops and starts
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover vtc 791nb-80 stops and starts
  • #94461
    delta01
    hi i recently fitted a new start capacitor on this machine it now runs about 20 mins then stops and after a while starts again i assume its a stat fault but not too familiar with these piles of rubbish any help appreciated thanks john
    #457425
    kaibart
    Re: Hoover vtc 791nb-80 stops and starts
    Either front ntc or heater by the sound of it check with customer if it’s heating up
    #457426
    delta01
    thanks it heats up ok the customer thought it was getting too hot but i ran it a few times and it worked ok except it stopped several times can the ntc be tested easily
    #457427
    kaibart
    Yes can be tested from pcb I think from memory it’s two yellow wires that goes down to ntc where is it kept if it’s not stored in a house more than likely ntc fault as this dryer is designed to work at ambient temp
    #457428
    wilf
    this might sound silly but I once had a machine that had a special feature to do just what your describing in order to prevent creases forming at the end of a cycle. cant for the life of me remember what it was but are you on a fully timed or auto cycle?
    wilf
    #457429
    delta01
    yes it does it at several times during the timed drying cycle thanks
