Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover VTS 712D21 Installation help please
- This topic has 9 replies, 2 voices, and was last updated 12 years, 3 months ago by
saisridhar.
January 18, 2014 at 7:41 pm #79079
saisridhar
ParticipantHi there,
I am trying to install my new Hoover VTS 712D21 washing machine but not sure few things from the Manual.
Here is the link for the manual
http://service.hoover.co.uk/content/manuals/VT714.pdf
I am unable to follow the 4 & 5 steps on Set up + Installation page(page 28)
Remove the 2 or 4 fixing screws marked (A) and remove the
2 or 4 spacers marked (B) (diagram 3).
Cover the 2 or 4 holes using the caps provided in the
instruction booklet pack (diagram 4)
Does it mean the screws in white circle(please see the attached pics).They are very hard.
Apply the insulation sheet of corrugated material to the base
as shown.
Any help is greatly appreciatedMany thanks
January 18, 2014 at 8:12 pm #407817Martin
ParticipantRe: Hoover VTS 712D21 Installation help please
Yes remove the 4 transit bolts (with a spanner) from the back panel then fit the 4 plastic caps on the holes left in the cabinet. Tip machine on its back and fit corrugated base.
January 18, 2014 at 9:03 pm #407818saisridhar
Martin,
Thanks a lot for your quick reply.
Just i want double check few things again.
1. I unscrewed (as pic below). Do I have to remove black spacers as well? Is it ok if leave black spacers to washing machine?
Finally I managed to do insulation sheet of corrugated material to the base
Many many thanks in Advance Martin
January 18, 2014 at 9:19 pm #407819saisridhar
Martin wrote:Yes remove the 4 transit bolts (with a spanner) from the back panel then fit the 4 plastic caps on the holes left in the cabinet. Tip machine on its back and fit corrugated base.
Martin,
1. I unscrewed (as pic below). Do I have to remove black spacers as well? Is it ok if leave black spacers with washing machine?
Finally I managed to do insulation sheet of corrugated material to the base. it is ok now.
January 18, 2014 at 9:20 pm #407820Martin
Yes remove the spacers…..!
January 18, 2014 at 9:23 pm #407821saisridhar
Martin wrote:Yes remove the spacers…..!
They are bit hard. I will try again.Thanks a lot Martin. You are star.
January 18, 2014 at 9:43 pm #407822saisridhar
Martin,
Yes, I removed the spacers as wellThe one marked in red (see below pic) that end goes to washing machine or cold water pipe line? Please let me know Martin.
I think I am nearly there!!!
thanks again Martin.
January 18, 2014 at 10:23 pm #407823saisridhar
ParticipantJanuary 18, 2014 at 10:23 pm #407824Martin
The angled end fits on the washing machine (see Page 29 of your installation instructions). This has been quite a journey hasn’t it…..phew!
January 18, 2014 at 11:10 pm #407825saisridhar
Martin wrote:The angled end fits on the washing machine (see Page 29 of your installation instructions). This has been quite a journey hasn’t it…..phew!
Thanks a lot for your help Martin. -
