Hoover W/D – A8754
  • #20474
    brett1611
    Hi – customer complaint is not turning during dry cycle. I’ve checked various things out and m/c turns on wash and spins fine. All the dryer section parts are working fine but the is NO motor action. Why ?? POSS bad contct in main timer maybe BUT I’M NOT SURE…….. !!!!
    #187191
    Re: Hoover W/D – A8754
    I’m not sure but doesn’t the A8754 have a seperate dryer timer? If so then maybe the motor supply on t/dry goes via the dryer timer…dunno?
    #187192
    scots
    Almost def the timer, there is one contact (4) used to control motor action, the dryer timer just controls dry time cutting out heat last 10mins.
    Try EMW for timer/module
    #187193
    biggoolie
    Try insulation test on Dryer element, low insulation can cause this fault.
