hoover w/dryer h3ds4855tace-80
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover w/dryer h3ds4855tace-80
Viewing 15 posts - 1 through 15 (of 17 total)
  • #102078
    adv
    hi this guys is coming up e 11 the pot state dryer limiter state is reading 37.8 ohms that normal ? also the small connector with the thin wires .the wires have come out while taking it off 😡 . wonder if its that . but what is the best way to fix the wires. ?i had a few spares of heater ones , cut some off with the wire still in .and just bullet connected them .got none left . any one got any other ideas to fix the wires ?i connected the two wires together . to see if customer could just get a few washes done , didnt help still got e11:rolleyes:?
    #487467
    connecting the wires together wont help as it looks for shorted or open ntc’s
    hoover only sell complete harness but you may find similar connectors somewhere else. these connectors are called insulation displacement connectors as the insulation is broken as the wire is pushed into a metal fork. you can use a small screwdriver to try to ease the wire back in
    adv
    hi can you get the wires back in decent enough its so tiny tho 37,8 ohms normal for these states ?
    #487469
    adv
    adv wrote:hi can you get the wires back in decent enough its so tiny tho 37,8 ohms normal for these states ?
    58 quid for a wiring harness and probably take about 3 hrs to fit all the other connectors .. rediculous:mad:
    #487470
    adv
    can you buy the we connectors anywhere ?:rolleyes:
    #487471
    adv
    Does anyone know what the ohms reading should be on this dryer heater state limiter ?
    #487472
    the overheat stats are just switches so zero ohms when closed meg ohms when open
    adv
    hi i mean the one at the front off the dryer heater casing ?the thermal limiter ntc ?
    #487474
    if you are telling me the NTC on the front of the duct is reading 11 ohms when not in circuit i would say thats too low by miles
    adv
    Hi it’s reading 39..6 ohms
    #487476
    adv
    It’s a e11 fault code
    #487477
    i would say that far too low
    41032956 should be the part no
    never seen such a rangs of prices for the same part
    Qualtex £5.58
    connect £15.53
    aswo £16.29
    although Aswo and Connect have alternative non gen parts
    as for the connector, had a look around but no luck yet. see if you can see a make on the old plug
    adv
    hi yeah ave got a spare connector will have to join it .39,6 ohms i thought that might be normal ?as you said if it was faulty you thought it would be open circuit . i have a zanussi type one it only reads 5.8 ohms mmmm ?:rolleyes:
    #487479
    have had them short and open circuit
    5.8 ohms is really suspect. most of the times these things go down in resistance when hot and at 5 ohms there is not much room to be accurate
    have you got an old heater ntc to link across as a maybe test
    adv
    going up later to have another look..:eek:
