Hoover WA110 washer/dryer No: 37613924 9904 6287
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover WA110 washer/dryer No: 37613924 9904 6287
  • #57385
    jontymox
    Good afternoon all,
    Wonder if anyone has expeienced an intermittent door opening problem on the above m/c?
    The door refuses/is very difficult to open sometimes, and when I called this morning it worked, although the door isn’t a very good fit, and not adjustable.
    The door lock is mechanical, together with the vacuum arrangement.
    When the push button is pressed, the mechanism is fine, so I’m wondering if it is related to the vacuum set up.
    If so, how does one test these?
    Could someone shed some light on the above problem?
    Best wishes,
    jontymox
    #330982
    Re: Hoover WA110 washer/dryer No: 37613924 9904 6287
    jontymox wrote:Could someone shed some light on the above problem?
    As a rule the cause is either or some of the following (most common reason first) 😉
    Push button pivot mechanism behind fascia panel wears and pivot rivets need crimping with a pair of molegrips to operate allowing greater movement on bowden cable.
    Pecker on drum pulley needs adjusting.
    Interlock assy needs replacing.
    Air tube gunged up.
    HTH? 😀
    #330983
    jontymox
    Thanks Martin,
    Yes, that information is most helpful.
    Will use if problem recurrs, as I didn’t charge for short visit today.
    Best wishes,
    jontymox
