Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover Washer/Drier Worn heater casing. Part Obsolete
- This topic has 8 replies, 4 voices, and was last updated 20 years ago by
7390ROBERTS.
April 6, 2006 at 7:37 pm #16967
7390ROBERTS
ParticipantHoover Soft wave washer/drier 1100 A875474200690
Hello All. I have a customer with this model need some ideas on a fix as part is now obsolete.
Has anybody come across this problem before.
The location tabs on the Drier casing that hold the heater element in place are worn and let the element move about causing an anoying rattle.
The Machine has been looked after and is still in good condition customer wants a repair if possible
So I would appreciate any ideas on how to repairThanks in advance
RobApril 6, 2006 at 8:34 pm #1723317390ROBERTS
ParticipantRe: Hoover Washer/Drier Worn heater casing. Part Obsolete
The casing i am talking about is the cast air duct on the top of the machine
Is there any way i can secure the element to stop it rattling aboutApril 6, 2006 at 9:44 pm #172332leavemetogetonwithit
In similar situations I have wrapped some thick wire round things to stop rattles. Of course the wire will rust but it’ll be a long time.
Mike.April 6, 2006 at 9:51 pm #172333Dave_Conway
The part numbers were in case anyone has either on the shelf:
09090317 (upper) and 09077934 (lower)
April 7, 2006 at 10:35 am #1723347390ROBERTS
Thanks Mike I have been giving it some thought overnite and am thinking of fitting a spring on the bottom of the Element then when the casing is closed it should keep it tight only worry is will it get to hot and heat the spring to much. Or would it be do any harm to the element if i just wrapped wire round a part of it to secure it.
If anyone else has any ideas i would like to hear them.Rob.
April 7, 2006 at 10:43 am #1723357390ROBERTS
Thanks Dave For posting the part numbers for me I appreciate it. If anybody has the parts will they reply please.
ROB
April 7, 2006 at 6:33 pm #172336leavemetogetonwithit
Presumably the element was originally touching the casing where it was held and this did not cause excessive heat transfer to the casing. IMO, since wire is round it will not have a large contact surface with the element and there won’t be a problem. I’m sure you won’t need to use much wire, just a bit where the original clip would have been to keep the element in position midway(?) between the upper and lower casings.
Mike.April 7, 2006 at 7:27 pm #172337Martin
Can’t you make up a metal bracket to fit over the securing bolt to act as a rigid plate where the housing has corroded?
April 7, 2006 at 9:02 pm #1723387390ROBERTS
Thanks Guys for the ideas will go and try something on them lines will let you know what happens
CHEERS LADS ROB
