hoover washer dryer
  • #96284
    wilf
    WDYN854B dryer not working tripped toc took apart cleaned reset all seemed ok now customer reports not working to temperature. I have never had an issue with ntc’s out of calibration before just had them go o/c. anyone had this problem ?
    thanks wilf
    #462894
    kaibart
    There maybe a issue with the fan motor they had trouble with these in that model
    #462895
    wilf
    blowing ok
    #462896
    even if it feels like its blowing ok it could still be partly blocked condenser
    cant see the condenser on the diagrams so I assume it may be built into the tub somehow
    wilf
    Four bolts and the complete blower/ heater box comes off you cant split it as the glue is too strong but you can wash it under a tap cleans it perfectly. the duct into the tub is straight down the customer even got his vacuum and sucked it out to his and my satisfaction. The water jet comes into the duct at the back I will check this again but there were none of the usual no condenser (hot and wet) symptoms
    thanks wilf
    #462898
    wilf
    I’ve been back to this machine to change the ntc which I found was rather loose. the toc had tripped again checked the condenser hose and jet all clear valve reads at about 4.6k machine runs, heats, blows, pump runs intermittently but in the nine or ten minutes I ran it there was no supply volts to the valve. all connections look good looks like a board fault unless anyone knows different e.g. does it take longer before the valve kicks in or would a load make any difference?
    thanks wilf
    #462899
    have found a test routine for it if you want to try that
    let me have your email
