Hi I have a problem this machine will not dry it seams to steam I have been told it may be a water value. so checked the value going to the condenser no water at all. so think the soleniod may be to blame.I know nothing about these things at all and need help.going to check Continuity
of soleniod then trying voltage to it.Is the voltage 240 volts or is it less. When dryer is running should the value be live all the time or is it controled by the programmer. Thanks for help. sorry about Typing not my thing. Waiting with hope Thanks…
Thank you will be careful with voltage check is there anything else to look for like water presser as it is running on a boat this is a new machine to me as my indesit bearings and spider have just broken and it had a sealed drum so wasn;t worth the cost thought about spliting drum and resealing it but gave up Thanks for help Pump presser about 1.5 bar it washes fine and old machine worked well
