The dryer will only run for ten minutes before the dryer timer runs back rapidly to the off position if it’s originally set to any time of 50 minutes or less. If it’s set to more than 50 mins it runs normally until it gets down to 50 mins and then runs back quickly to off. Is it the dryer module causing this? This timer was replaced a year ago. I’ve also had to replace the condenser inlet valve and the blower motor recently which was seized. Could this have damaged the module?
Any ideas would be appreciated. Thanks.
Geoff
