Hoover Washer Dryer WDYN went Pop!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Washer Dryer WDYN went Pop!!
  • #91628
    JamesBlague
    Hi UKW!
    Hoover Washer dryer WDYN etc.
    59 min 40deg wash on small load – 3 shirts
    When over, hadn’t spun, still wet, water in drum.
    Understand load prob too small/uneven to spin.
    Put on 7min spin (as done successfully many times previously)
    Again, failed to get up to speed
    Then… “POP”!! A loud, electrical type, fuse/component blowing sound, sockets RCD tripped.
    Back on, fuse fine, display on, lock light flashing permanently, doesn’t engage, same in any programme, nothing further happens.
    Lid off, back off, control/display circuit board out, nothing visibly wrong.
    Mains filter seems fine, although small amount of dried (a day later) yellow liquid on bottom.
    Back panel covered in fine “soot” inside – but presume belt dust rather than from any smoke? (It’s four years old exactly.)
    Something, probably electrical, went pooff when it was trying to run up a spin – sounded just like a lighbulb popping – guessing I need a new one of whatever that component is – any ideas?
    Thanks so much
    James
    #448793
    Re: Hoover Washer Dryer WDYN went Pop!!
    well cant be certain without full model but if it has a brush motor check the brushes first
    kaibart
    Post full model up and we maybe able to help you further
    #448795
    JamesBlague
    Sorry folks, schoolboy error.
    Hoover Washer Dryer Model number:
    WDYN 856 DS (-80)
    Thanks all
    James
    #448796
    kaibart
    Sounds motor or pcb related to me
    #448797
    JamesBlague
    Looks like the “pop” was a bit of the ECB PCB blowing off – the components on the other side seem fine but there is a bit of the circuit missing and blackening on the board and the nearby white plastic cover (see photos).
    Do you think a straight replacement will fix it or is there a secondary problem?
    Thanks again for pointing me at the PCB!
    James
    #448798
    kaibart
    I would say it needs a new motor and pcb not cheap though
