Hoover Washer/Dryer WS130
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Washer/Dryer WS130
  • #10787
    satinser
    Machine attempts to spin during wash cycle have noticed that it only happens when rotateing in anti clockwise direction. It even attempts to spin when drum is full of water in rinse cycle
    I suspect its the circuit board attached to the programmer which appears to regulate the speed of motor at fault. I have checked posts going back a year or so on this forum and found no posts with a similar problem to this.
    Would be very grateful if someone in the know would offer comments on this particular fault and other possible causes of such a problem if known.
    #142727
    Re: Hoover Washer/Dryer WS130
    The problem is usually due to the Tacho Generator Coil going open circuit 😉 Maybe just that the terminals into the motor terminal block are broken at some point even 💡
    Easy job to sort and we may well have an expert to fix it for you by clicking on this link:Repairs@
    #142728
    satinser
    Thanks Martin for the reply, wherabouts is the tacho generator coil and what does it look like?
    #142729
    Magnet and coil on the end of the drive motor. Power off if investigating.
    satinser
    So the main drive motor is the problem and not the programmer as I thought, and the part of the motor that is causing the problem is the part that governs the speed and is called the tacho generator coil.
    The next question is can that part be repaired or replaced or is best to replace the main drive motor in its entirety?
    #142731
    Dave_Conway
    They can be replaced, part number is 91212340 at £9.95 inc VAT and post.
    I can order and send one if required, an email to spares@ukwhitegoods.co.uk 😀
    #142732
    satinser
    Thanks for the information Dave, will be emailing you for the part. 😆
