Home › Forums › Public Support Forums › Spare Parts Help › hoover washer H110M
- This topic has 8 replies, 3 voices, and was last updated 20 years, 8 months ago by
admin.
August 7, 2005 at 8:21 am #11145
KeymasterI think i need new bearings for the drum on our Hoover H110M washer, it is becoming very noisy, i have removed the drive belt and the drum is very ‘rumbly’ when rotated by hand also i can feel some movement when i grab the outside edge of the drum and move it up and down, can i just replace the bearings or is it a complete assembly, what will it cost and how difficult is it to do?
cheers!August 7, 2005 at 11:14 am #144128Martin
ParticipantRe: hoover washer H110M
You will need a drum bearing and seal set plus a inner drum spider assembly and a outer drum seal. 🙁
It’s a hell of a tough job to do mind you as the whole drum has to be extracted from the cabinet before you can even attempt to remove the old bearings 🙁
Best of luck!
August 7, 2005 at 1:19 pm #144129admin
KeymasterRe: hoover washer H110M
Cheers Martin,
i thought the drum may have to come out when i took the back off to check the noise, i’ll give my local repair shop a call on monday for a price and i’ll compare it to the cost of the parts, when i get a price on them.
August 9, 2005 at 4:22 am #144130admin
Contacted my local repair shop today and they basically said new bearings cannot be fitted, a bearing kit is no longer available from hoover and that i would have to buy a complete drum assembly at around £100, is this the case?????????? If so i am probably better buying another machine??
August 9, 2005 at 7:26 am #144131Martin
Anonymous wrote:Contacted my local repair shop today and they basically said new bearings cannot be fitted
That’s true, just checked up on supplies myself and it has to be a complete Drum Assy at around £100 or so 🙁
You’d be better off buying a BOSCH 🙂
August 9, 2005 at 7:00 pm #144132admin
looks like a new machine then.
Martin, i take it you think that bosch are the best in the market?
August 9, 2005 at 7:04 pm #144133Penguin45
Bosh represents excellent value for money, when compared with some of the cheap tat around at the moment. The best is probably Miele – you’ll only ever need to buy one 😀 . But, you pay…
Penguin45.August 9, 2005 at 8:38 pm #144134admin
Cheers Penguin,
when i’m off work i’ll have a closer look at bosch/miele washers.
PS, it’s thanks to you i found this site, i saw your link on UKsaabs, I’m sonett.
August 10, 2005 at 12:01 am #144135Penguin45
😀 . Hi Sonnett – I’ll have a flake with mine thanks!
