hoover washer no drain Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hoover washer no drain This topic has 3 replies, 3 voices, and was last updated 18 years, 2 months ago by abbots. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts February 7, 2008 at 4:44 pm #34414 abbotsParticipant hi, AMA122 07 37616109 can’t get machine to drain. will spin,fill etc but no pump action. pump ok supply cables to pump ok. element ok valves ok p/s seems to operate fine. i suspect the module. Any one else any thoughts on this one. thanks. john February 7, 2008 at 5:18 pm #242532 trotterParticipant Re: hoover washer no drain Soubnds like you answered your own question! There is nothing else in the circuit is there? for what it is worth I would go for the module too. Andrew February 7, 2008 at 6:49 pm #242533 timdowningParticipant Re: hoover washer no drain Change the pump as well while your at it just in case the old pump faulted the pump triac. Check that the breather tube from pump to dispenser isn’t chaffed as well. February 7, 2008 at 7:12 pm #242534 abbotsParticipant Re: hoover washer no drain cheers guys. jk Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
