Hoover washer WMH139D – unintelligible flashing display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover washer WMH139D – unintelligible flashing display
  • #86297
    twicknix
    The display was flashing and does not make sense.
    Meggered the wm – dirty motor, cleaned up and insulation improved.
    Heater ok
    Motor looks clean and air brushed commutator clean
    Gonna try pressure switch to see if it helps
    Lower control board clean as a whistle and same for facia control board.
    Any ideas before I write it off or spend money on new boards?
    #430744
    twicknix
    Re: Hoover washer WMH139D – unintelligible flashing display
    To better explain on how what’s going on with the machine,
    the machine pumped the water out intermitted and at same time the display board was flashing. The digits were not clear.
    Pulled the mains plug, the display showed up as normal. Select Spin then pressed start, then it started going funny. The pump appears to be sound, no blockage or jamming.
    I have tried swapping the pressure switch and no change.
    The machine is 2 years old.
    Any thoughts?
    Matt
    #430745
    twicknix
    Sorry to be a pest, the owner of this dreadful machine is eager to know what am I going to do about it.
    I’m hoping for some answers…. Pretty please…
    #430746
    clockworkone
    Selector switch. Switch on machine. Tap control knob lightly to see if display flickers.
