Re: Hoover washing machine HNF7167
If the pump connector plug had signs of burning on it then its odds on that it has had a slight leak from the inlet hose onto the pump, you rarely see the leak on the floor, a bad design to have an uncovered pump directly under a potential leak area.
Not sure how clued up you are electrically but you need more than a live feed. 😉
If you can get the pcb out I will bet good money that you will find blown components in the middle of the board, done with with the mains plug removed. :zap:
NB. There is no need whatsoever to ‘live test and ‘ given your questions about the live feed you have to the pump I would respectfully suggest you get someone with the proper skills to assist you.
