hoover washing machine oph714d/1-80
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover washing machine oph714d/1-80
  • #49421
    dealdd
    went out to this machine on friday and customer complaing about it stoping in cycle and showing error e03 and e16. found code for e03 which is drain failure. checked all pump filter and hoses all ok.
    can anyone tell me what e16 is, if its a real error code.
    also does anyone have a test procedure for this machine or any paper work which may help
    thanks
    #299874
    loopey
    Re: hoover washing machine oph714d/1-80
    e16 is Water Heating Element is short circuited or defective electrical insulation , very common fault
    hth phil
    Push and hold the FIRST Option Button with LED to the left .
    • Turn the Program’s Selector Knob 2 steps in clockwise sense.
    • After 5 seconds, release the FIRST Option Button with LED to the left.
    • If the previous procedure was correctly carried out, all LEDs are switched
    ON simultaneously…………..
    Push the START/PAUSE Button , to start the Selfdiagnostic
    sequence.
    3) DESCRIPTION OF THE SEQUENCE OF SELF-DIAGNOSTIC ROUTINE:
    • Water is loaded to fulfill the “basic” level of 6 liters, through the Detergent’s
    Compartment for Pre-wash (I).
    • 1 second of pause.
    • It’s fed for 20 seconds, the Water Heating Element (~8 A on the Digital
    Ammeter).
    • Timed water load is carried out through the Detergent’s Compartment for
    Main Wash (II), water supplied by the Cold Water Solenoid Valve (and
    by the Hot Water Solenoid Valve, when present). It’s fed the Motor for
    the tumbling of the Drum in Anticlockwise sense at 55 rpm and for the
    time of ~ 16 seconds.
    Pause of the Motor for ~ 4 seconds. The timed water load continues, as in
    the previous paragraph.
    • The timed water load is ended through the Detergent’s Compartment for
    Softener (��). It’s fed the Motor for the tumbling of the Drum in Clockwise
    sense at 55 rpm, for the time of ~ 12 seconds.
    • It’s fed the Drain Pump, until “empty tank” Pressostat’s condition.
    • It’s carried out a Short Spin Phase, lasting ~ 15 seconds, at the half of the
    maximum speed available and then the Self-diagnostic sequence is ended.
    • At the end of the sequence of Auto-test, all LED flash together.
    NOTE:should have end in window ….
    #299875
    dealdd
    cheers phil went back run test and run nmachine for a while sure enough element low insulation
