Hoover WD. E22
  • #96557
    CJonesDAR
    Hoover washer dryer model WDXOC485A/1-80 Dynamic Next. E22 after a couple of minutes. Any advice would be appreciated. Thanks
    #463904
    looks like a heater fault
    CJonesDAR
    Thanks for reply. That was the my first thought. Checked wash and dry elements for earth faults but they were ok. Ordered and replaced module but same fault.
    #463906
    you say you checked elements for earth faults I am assuming you checked for continuity as well
    kaibart
    E22 is a drain fault check change pump
    #463908
    CJonesDAR
    I had forgotten to test the wash element for continuity. . Element O/C. New element ordered. Thanks.
    #463909
    TST1000
    Hi I know this is an old post but I have the same issue on a HBWD 8514S-80, I have changed the heater element but am getting the same error, could this be control board?
    Thanks,
    #463910
    as the list above could also be wiring or board
    TST1000
    Thanks Dave, did not expect a response that fast! Will get the board out and check connections. Thanks again
