Hoover wdm 130 won’t spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover wdm 130 won’t spin
  • #10988
    In the cycle 4 spin the machine does no more than give a few half hearted slow spins. leaving clothes very wet. Have checked the pump and removed a coin from the pipe running from the drum to the pump but no change. Any advice on where I should look next
    #143456
    Dave_Conway
    Re: Hoover wdm 130 won’t spin
    It may be the brushes on the motor are worn down perhaps ?
    Is it draining quite quickly ?
    Power off when checking please :zap:
    #143457
    Seems to drain down fine. Might be the brushes but its not very old2-3 years and doesn’t get hard use
    #143458
    Found the problem a bad solder joint on one of the relays on the motor control PCB. Repaired and its working fine
    #143459
    I’ve just moved into a new house which has one of these. It doesn’t appear to be working properly but we haven’t got a manual for it and Hoover will charge to send one out. Is there any chance you could give me a quick run-down of the basic programmes (i.e. how to put on a standard wash, rinse and spin)? I have a seperate dryer so it’s just for washing.
    Cheers! 🙂
    #143460
    Anonymous wrote:I’ve just moved into a new house which has one of these.
    As an aquisition your Hoover machine is well worth investing in a User Instruction Booklet to show you all the comprehensive features available from it. 🙂
