Hoover WDM130-01
  • #30046
    mjhservices
    The motor on this turns only in one direction anti clockwise, I can hear the relay on the board clicking on and off to turn clockwise but the motor does not turn that way.
    Is this a motor fault or the PCB board?
    Regards Mark
    #225657
    Re: Hoover WDM130-01
    PCB – relay faulure.
    timdowning
    You can normally seen the bad solder point on the PCB. Give it a clean up and a blob of solder. (usually does the trick.)
