hi guys just been to this e11 fault was hoping to see the drier wires broken seem fine ,, the sensor state …am getting a ready only on the highest ohms scale 2000k of about 100 . is that normal ? if is ? what else could it be ? pcb ❓
I’ve put exactly what’s on Hoover’s service error code list my sure ntc should read about 28kohms. Only faults I’ve had on these are blocked condenser and the fan motor coming loose on upper housing.
ok cheers ..looked on connect. model doesnt even register. qualtex here ..sensor not listed even on hoover site mmmm strange..aaahhh through too feck then
It’s the wrong model number thats why 3 listed wdyn854dg-86s wdyn854db-80 wdyn854d-80 sensor should be the same on all 3 models will pm you some info kai
😡 thats off front of machine.. weird took photo // although didn’t check label in door …. mmmm if things arnt hard enough .. putting dodgy model nos on faciers .. :eeek:
