Hi Guys, above washer/dryer keeps tripping heater cutouts. Fan ok, water to condenser ok. Is this likely to be the thermistor on the front of heater housing causing this problem? Anyone know what thermistor reading should be?
It’s likely to be a blocked condenser unit which will need cleaning with a metal coat hanger or something similar or the fan blade will be full of fluff this is what will be causing the problem I’ve done so main I’ve lost count can take more than 1 attempt so expect a recall on it they are a nightmare kai
