hi are the thermistors on these likely to cause this problem in my experience thermistors are very reliable i have checked for airflow which is good any help appreciated thanks John
problem with these built in condensers is you can see if there is a blockage at the bottom. used to get this a lot on older models and they used to blow TOC. when you checked air flow it seemed fine but obviously was not quite enough
