Hoover WDYNS 654D Squeaky/Ratcheting drum
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover WDYNS 654D Squeaky/Ratcheting drum
  • #60873
    danielnez1
    Hello,
    Continuing on from my post on another tread about my Hoovers squeaky drum, I called Hoover to ask about it and they send someone out to check it.
    When the service guy came around, he loaded it 3 quarters full and chose a cycle. As it does every time, the drum made an squealing/ratcheting sound as it turned. Next he tried a spin cycle and it continued to make the noise but subsided as soon as it began to spin.
    He said that since it didn’t make the sound when it spun that he didn’t think anything was wrong with it. When I asked what he though the sound was he said he didn’t really know but it could be detergent around the baring seal.
    Now am I being paranoid or is there actually something wrong with the machine? 😥
    Cheers,
    Dan
    #343965
    danielnez1
    Re: Hoover WDYNS 654D Squeaky/Ratcheting drum
    Something else, my partners previous flat they rented included a Servis Washer Dryer that the same sort noise (only difference was that it made it throughout the wash cycle apart form the spin) someone came out to look at it and said the belt was on its way out.
    Putting two and two together, would it be safe to say that the Hoover has the same issue?
    Cheers
    Dan
    #343966
    suedehead1
    more likely to be the bearing seal.
    you would think the engineer would have checked the belt and possibly slack drum pulley
    #343967
    danielnez1
    I’ve had the same person twice now – the first time I called them out he didn’t seem too bothered that after a rather nasty out of balanced spin it had dented the rear panel and a bit concrete off the counterweight had broke off and wedged its self in the drain cover.
    I’ve made a video of the drum noise, if anyone wants to look:
    http://www.youtube.com/watch?v=Yd0YlWAxsyU
    I know one thing for sure, its lesson learned for me. 😳
    Cheers,
    Dan
    #343968
    suedehead1
    it sounds like there is a bra wire under the drum to me,
    have you tried to look down through the holes in the drum shining a torch to see if there is anything there.
    or its a loose drum pulley.
    #343969
    danielnez1
    No bras have been washed in the machine. I have tried to look between the holes with a torch before and I couldn’t see anything.
    Could it be possible to remove a paddle to have a better look?
    It’s drying at the moment and the sound has subsided.
    Cheers,
    Dan
    #343970
    danielnez1
    For a comparison, I’ve also recored what the drum sounds like after the drying cycle, but it is usually the same after a washing cycle as well:
    [youtube:2ti686o1]http://www.youtube.com/watch?v=YXgGMAIrDFs[/youtube:2ti686o1]
    Cheers,
    Dan
    #343971
    danielnez1
    An update, after complaining the engineer came straight back to check the machine. Unfortunately it didn’t make the noise as it was mid way through a cycle.
    However, he did take a look inside and took out and re inserted the heater and it seems to be OK now.
    It still rattles and shakes during the spin (it is level though) but I suppose beggars can’t be choosers. 🙂
    Cheers,
    Dan
    #343972
    danielnez1 wrote: but I suppose beggars can’t be choosers. 🙂
    Correct, but choosers can buy better quality machines in the first place. 😉
    #343973
    danielnez1
    Well there is now a new issue with it; on the spin cycle it now makes a new rattling noise. I’ve made another video but it doesn’t capture how loud the noise actually is.
    http://www.youtube.com/watch?v=n-DksAOlbkI
    #343974
    danielnez1
    Just noticed that the ratachting sound in the drum has started again 😥 it’s ether callout number 4 or give Currys a ring.
    #343975
    suedehead1
    phone hoover show them your video. it sounds like a loose dryer element or broken spider.
    #343976
    danielnez1
    I’ve called them out and they will replace the machine if they find any faults (its just turned 4 months old now).
    #343977
    danielnez1
    Another engineer came and it wasn’t in his notes that the machine was to be replaced. After getting in touch with the store, the person who told Hoover Candy that the machine should be replaced said I have to submit in writing that the machine should be replaced to Currys CS 👿
    The engineer replaced the heating element as the seal was failing. You can also see where the drum was rubbing against it. Despite replacing the element, the drum is still making the Squeaky/Ratcheting sound and the machine still makes the same rattling noise during its spin as well.
