hoover wiring harness
  • #28914
    abbots
    hi guys,
    HNF3157-80
    31000603 0428
    does any one know if you can get the part of the wiring harness that goes from the front timer selector to the PCB control module.
    it has burned out after rubbing on the drum, and also damaged the edge connector where it goes on the PCB module.
    it looks as if it’s in 2 parts, one is all red wires, the other is red and black wires.
    they connect to the PCB (looking down from the top) on the bottom of the PCB on the left hand side.
    if not what is the part number for the complete harness?
    thanks
    john.
    #220630
    Re: hoover wiring harness
    Timer harness listed as 91201360 – can’t find an image though.
