I’ll email you a wiring diagram shortly but looking at it everything points to the main PCB, part number is 97923619 and at a little under £40 not too pricey 🙂
maybe,but looking at the wiring diagram the drain pump will still run if the
contacts are not made in the interlock,and the” door locked ” light on the front wouldn’t work if the interlock contacts were not made.
jk
cheers,
sounds like a board replacement whatever the cause,customer doesn’t think he wants to pay more than £70 for repair,so it could be a no go.
thanks.
john
