Hoover Wmh 147DF/2-80 error code E04
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Wmh 147DF/2-80 error code E04
  • #81482
    Silentmelons
    Hi all,
    Just picked up this washer “refurb” and been having a bit of a nightmare with it. Had to replace a couple of clamps on the waste pipe from the drum to the waste pump because they were leaking. Also had to clamp on what looks like a vacuum hose from the control panel to its connection point on the drum as this was also not connected.
    I tested it yesterday and managed to get a full cycle out of it. Today attempted to use it and it stopped mid cycle with error code 3 and wouldn’t drain. I removed the waste pump and cleaned the filter checked seals and re connected.
    Tested again with a little water drained ok.
    Now when I try and run any cycle I get error code 4 I believe this means it’s overfilled? This error comes up straight away even though the machine is empty?
    Any suggestions?
    Thanks,
    #416778
    Re: Hoover Wmh 147DF/2-80 error code E04
    The air chamber (integrated into the sealed tub) could be gunged up? That’s connected with a thin rubber pipe and goes to the pressure switch attached to the top frame. Has this machine been transported on its side or perhaps tipped upside down by any chance?
    #416779
    Silentmelons
    Thanks for the quick reply. It has recently been moved but on a sack truck so shouldn’t have gone over 45 degrees really. I will check said tube now and feedback. Thanks.
    #416780
    Silentmelons
    This is now sorted thank you for your help. Quick blow down the pipe and we are back in business.
