Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover WMH147 Error E03
- This topic has 30 replies, 3 voices, and was last updated 6 years, 1 month ago by
Alex Facey.
March 6, 2020 at 11:19 pm #97296
Alex Facey
ParticipantHi, I have a Hoover WMH147 that throws E03, the drum fills but refuses to empty and times out.
I’ve replaced the pump, checked drum-pump hose, checked pump outlet hose. I’ve tried disconnecting the heater element.
What do people suggest I try next? (For information if I manually empty the drum then the error disappears which makes me think the pressure switch works.)
Small bit of additional information, pump meters out at about 160 Ohms (which I think is about right.)
It just seams no matter what the pump won’t run.
March 7, 2020 at 8:33 am #466911Alex Facey
ParticipantI’ve carried on fiddling around with this but still no luck, no matter what the drain pump refuses to run
March 7, 2020 at 10:42 am #466912Alex Facey
ParticipantAnyone got any suggestions please, all I can think of now is replacing the control board but don’t want to just throw money at it.
March 7, 2020 at 10:55 am #466913electrofix
Moderatorwas the pump faulty when you removed it ?
did it look like water had been dripping on it ?dave
March 7, 2020 at 11:03 am #466914iadom
ModeratorAn insulation fault on the heating element is a known cause of spurious F03 errors on these.
March 7, 2020 at 11:42 am #466915Alex Facey
Participantelectrofix wrote:was the pump faulty when you removed it ?
Dave,
No the pump looked okay and meters out okay, new pump displays exactly same symptoms of just never trying to run.
March 7, 2020 at 11:43 am #466916Alex Facey
Participantiadom wrote:An insulation fault on the heating element is a known cause of spurious F03 errors on these.
Thanks for the reply, unfortunately when I disconnect the power and earth wires from the element it made no difference.
March 7, 2020 at 12:05 pm #466917iadom
ModeratorExamine the small connector plug to the pump, I have seen the slightest sign of arcing due to water ingress damage this plug but you really need to look very closely to see it. Sadly if that is the case then module damage has often occurred. A quick visual on the component side of the module usually shows signs of component damage. The water inlet hose from the soap dispenser often leaks as the adhesive sealant deteriorates.
March 7, 2020 at 12:23 pm #466918Alex Facey
Participantiadom wrote:Examine the small connector plug to the pump, I have seen the slightest sign of arcing due to water ingress damage this plug but you really need to look very closely to see it. Sadly if that is the case then module damage has often occurred. A quick visual on the component side of the module usually shows signs of component damage. The water inlet hose from the soap dispenser often leaks as the adhesive sealant deteriorates.
Thanks for the advice, I’ll give the connector and control board a more detailed inspection and see what I can find.
March 8, 2020 at 10:01 am #466919electrofix
Moderatorare you sure this is the correct public link as it does not seem to work
March 8, 2020 at 10:38 am #466920Alex Facey
Participantelectrofix wrote:are you sure this is the correct public link as it does not seem to work
Dave,
Thanks for the heads up, link has now been edited.
Cheers
March 8, 2020 at 10:41 am #466921electrofix
Moderatorstill cant see it
March 8, 2020 at 11:02 am #466922Alex Facey
Participantelectrofix wrote:still cant see it
Did you try the top link out of the 2?
March 8, 2020 at 11:02 am #466923iadom
ModeratorMe neither.:(
March 8, 2020 at 11:14 am #466924Alex Facey
Participant -
