Hoover WMH147 Error E03
Viewing 15 posts - 16 through 30 (of 31 total)
  • #466925
    top link works
    you should find thats dust attracted to the high voltage and should go with a paint brush
    need to see the other side of the board. that likley where the traic will be that contols the pump and valves etc
    Alex Facey
    It very looks like “magic smoke” evidence to me but okay, next thing then is I’m still no closer to knowing why it won’t run the drain pump?
    All the help and suggestions are very much appreciated though guys!
    #466927
    Alex Facey wrote:It very looks like “magic smoke” evidence to me but okay, next thing then is I’m still no closer to knowing why it won’t run the drain pump?
    its not smoke, see it all the time around high voltage components and these are operating at 300v DC
    Alex Facey
    Dave,
    Any further suggestions where I go from here?
    #466929
    as i said above i need to see the other side of the board
    Alex Facey
    electrofix wrote:as i said above i need to see the other side of the board
    Dave,
    Otherside of board confirms board is toast : (
    https://flic.kr/p/2iC2swR
    Any idea where I can get a replacement?
    Thanks.
    #466931
    to be able to look up the part number i will need all the numbers on the label inside the door
    there are 4 machines with similar model numbers and i need to narrow it down
    Alex Facey
    electrofix wrote:to be able to look up the part number i will need all the numbers on the label inside the door
    Dave,
    Thanks, to ensure accuracy I’ve taken a pic of the label.
    https://flic.kr/p/2iBZ1jm
    #466933
    well part number i get is
    49025085
    looked around and cant see it
    you could email the site shop to see if they can supply
    alternatively
    try https://www.qer.biz/servReps.htm
    see if they can repair it
    Alex Facey
    electrofix wrote:well part number i get is
    49025085
    alternatively
    On the front side of the board is 41033492
    Does that help at all?
    Alex
    #466935
    that number does not help. the part no above should be correct for your serial and model you just need to either get it repaired or find someone with stock or at least a price first
    Alex Facey
    I found one at a company called Ransomspares for £118, does that sound about right?
    #466937
    i would ask the site shop and hoover themselves. some internet sites inflate the price
    after all if hoover dont have stock then nobody can get it anyway
    Alex Facey
    electrofix wrote:i would ask the site shop and hoover themselves. some internet sites inflate the price
    Dave, thank you, that’s good advice.
    Cheers
    Alex
    #466939
    Don’t think those small Chinese modules are anywhere near that price. Would advise checking the wiring plug very carefully and check for leakage from where the soap inlet hose is slotted into the drum. You will need to peel back the door seal to check.
