hoover wmh148df continous turning on and off
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoover wmh148df continous turning on and off
  • #78342
    DDA
    I have a hoover wmh148df that is continously turning on and off as soon has been turned on.
    I have prevously had simalar isues with a smeg dishwasher thet was sorted with a few capacitors on the pcb.
    Will this be a similar fault and can anyone point out witch components need replacing. if not dose anyone have any experience with this fault as customer not wanting to stretch to a replacement pcb.
    Any help would be appreciated, don’t like writing machines off unless i have to.
    #405321
    Re: hoover wmh148df continous turning on and off
    It’s a bit “how long is a piece of string?” this one TBH. If it goes through the cycle like this then I would think interlock probs? But if the programme continually needs resetting to start a connection issue to or within the coreboard? Dunno, go take a closer look and let us know what it was. 😀
    #405322
    Hollytree_Technical
    I don’t know the board but going from the images on connect I would guess that you would want to look at changing the 400V electrolytic capacitor and 8 Pin IC next to it.
    Jem
    #405323
    DDA
    Sorry looking back my description of the fault was a bit vague.
    As soon as the machine is turned on the pcb power up then down again every 5 ish seconds.
    No programs have been started.
    hope this helps
    thanks Jem, I will look for the parts you mentioned ready to try.
