Hoover WMH168D Fault Code E08 – HELP
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover WMH168D Fault Code E08 – HELP
  • #85868
    dalton565
    Hi guys
    I have a Hoover WMH168D washing machine that has developed a fault and is showing E08 error code.
    The machine will fill and drain ok, but will not spin at all (No life whatsoever from motor). I have taken the motor out and examined the brushes and they are in good condition, and there is plenty left on them. I have tested the tachometer with a multimeter and it is showing correct resistance 43.7 and varing when spinning the motor.
    The machine is approx 3 years old and is only used lightly, it had a new PCB installed under warranty after about 6 months.
    Do you think the problem lies in the PCB or the motor or somewhere else maybe, parts are available pretty easily, new ones are a bit expensive so i was thinking of buying 2nd hand from ebay.
    All help appreciated
    #429698
    Allsorts
    Re: Hoover WMH168D Fault Code E08 – HELP
    Possibly the motor drive section on the pcb
    #429699
    dalton565
    Thanks have order a new PCB so will give that a go and report back.
    I noticed a 2nd PCB device inside the machine, just under the lid on the right hand side do you know what this is for ?
