Hoover WS130
  • #11172
    my WS130 washer/dryer is filling itself with water whilst turned off.
    I’m having to do a spin dry before being able to open the door.
    Can anyone offer any advice about which part/valve is passing?
    Cheers
    #144218
    Dave_Conway
    Re: Hoover WS130
    It may not be the valve, sometimes the waste hose poorly positioned can do this by syphoning.
    If you check that first, if it’s attached to a spiggot on the sink waste then it needs to go up higher than the base of the sink at some point.
    If the valve is the fault, it’s normally the cold due to the higher pressure over hot. Easy way to find out is turn one of them off at a time and see which still lets water by.
    Valve details:
    Cold – 91213546 at £16.05
    Hot – 92202852 at £20.50
    Post £3.95
    If you need either of them, I can order, an email to spares@ukwhitegoods.co.uk please 🙂
    #144219
    Washman
    Re: Hoover WS130
    Hi Brummie
    Turn Cold tap to machine off and leave , If it fills you know its the Hot Valve leaking ,if it Doesnt fill you know its the cold valve leaking .
    Then we know which valve you need
    Mike
