Hoover WyDN855
  • #89396
    candice62
    The machine intermittently refuses to unlock the door. Sometimes it will quietly click and unlock perfectly at the end of the cycle, other occasions it will clunk a few times and then open. Sometimes it clunks 5/6 times and then I turn the dial to off and a minute or so later it quietly clicks and the door can be opened. Three of the last four washes it’s decided it won’t stop clunking and trying to unlock until I switch the damn thing off at the wall, the other one it opened perfectly. I’ve had it 3 years and it’s been doing this intermittently now for 18 months. Any ideas ?
    #441268
    kaibart
    Re: Hoover WyDN855
    Yes probably a fault on motor
    #441269
    candice62
    Re: Hoover WyDN855
    What motor? It’s the door lock mechanism
    #441270
    kaibart
    Re: Hoover WyDN855
    If there is a fault on the motor this can affect the door lock I’m an ex hoover engineer
    #441271
    candice62
    Re: Hoover WyDN855
    Can you explain exactly what motor you mean please.
    #441272
    kaibart
    Re: Hoover WyDN855
    There is only 1 motor fitted on this any machine if your not familiar with what a motor is I think it’s best for you to get someone to look at it
    #441273
    Re: Hoover WyDN855
    candice62 wrote:Can you explain exactly what motor you mean please.
    His somwhat enigmatic response actually refers to the main drive motor. Often the electronics can get confused over spurious electrical interference and in this instance could well be the motor. Specifically displaying an electrical short to earth, the carbon brushes worn or its windings shorting.
    I hope you now fully understand? 😀
    #441274
    candice62
    Re: Hoover WyDN855
    Thanks Martin. I did understand to a point. I was just trying to get him to be more specific. I’m convinced the problem relates to the interlock. Obviously it’s not broken as the problem wouldn’t be intermittent. Do you know whether this model relies on a pressure chamber or a bi metallic strip to engage/disengage the interlock?
    #441275
    Re: Hoover WyDN855
    It’s a bi-metal device powered via the PCB not the pressure switch.
