Hoovers cut out
  • #35131
    Loulou28
    I am having problems with two hoovers, they stay on for under 5 minutes, get very hot then cut out and won`t work again for ages.
    I have been having work done in my home, walls knocked out, total re-wire etc… and obviously i`m using the hoovers to get rid of the dust. I think that the fine dust has got into the motor and that is what is causing my problems, i`m probably wrong 😆 but its the only thing i can think of why both are doing the same thing.
    Can anyone advise please what i should do, if anything.
    I keep emptying the rubbish out ( both are bagless) each time i have picked up. I `ve checked the filters and they dont seem bad.
    I`m stuck now so some advice will be much appreciated.
    #245235
    kladave
    Re: Hoovers cut out
    If you are sure the filters don’t need cleaning and there are no blockages then the motor is at fault.BTW brick/plaster dust is just too fine for most domestic vacuum cleaners.
    Loulou28
    Re: Hoovers cut out
    Thanks Dave, i just cleaned both hoovers thoroughly including filters again and the motor as much as i could, so i`ll see tomorrow if they work properly again. Hope so 👿
    thanks again xx
