HooverSpecial Edition Washer Dryer Water problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HooverSpecial Edition Washer Dryer Water problem
  • #13237
    dan0k5
    hi i need some help for my hoover washer dryer HSW110M
    Problem = occasionally when it fills for wash it flows water out down the drain, but no drain pump running but that is only occasionally
    When filling for second rinse on any programme, it flows water down drain whilst filling thus never filling to right level and fills continously yet again no drain pump running
    Any help appreciated
    MANY THANKS
    #153715
    Re: HooverSpecial Edition Washer Dryer Water problem
    Syphoning………. If the end of the drain hose is pushed to the bottom of the stand pipe the water will run in after the wash cycle, and …. run straight back out again. The end of the drain pipe should be set at least 2″ higher than the highest water level used in the wash programme. If you’re not sure, make sure it’s above the half way lineof the drum.
