Called out to a Neff S51T69X1GB/15 dishwasher, initial code E26, did usual check and found drain pump restricted by elastic string. Removed and tested. Code E16 appeared ( Inlet valve fault), checked voltage to Aqua stop fill hose and I am reading 240+ volts. Ordered new fill hose connected and would still not fill, but still getting 240+ volts to hose connector. All the other components check out ok as I bypassed the automated fill house and manually filled. What are your thoughts?
Sent from my iPad using Tapatalk
