Hoptpoint Aquarius WDL 540 washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoptpoint Aquarius WDL 540 washer dryer
  • #71432
    taichibob
    When the machine is switched on an prog set,it’s takes some water in and waits then it takes more water. Then All the function lights flash at a constant flash rate. And the machine just sits ..
    Help
    #381027
    Re: Hoptpoint Aquarius WDL 540 washer dryer
    Do you mean ALL the lights flash very fast or is it just the mains light flashing rapidly and some of the left hand column of lights blinking slowly.
    If they are all flashing then the main pcb is faulty.
    #381028
    taichibob
    Yes all 4 function lights
    Super wash
    Extra rinse
    Mini load
    Slow spin
    #381029
    So ALL the lights are not flashing, only the option ones.
    Those lights are not used for error codes so it could well be that the facia PCB is at fault. Quite common on these low end, Indesit electronics. 🙁
    #381030
    taichibob
    Have been to look again
    All function buttons are flashing
    Including start/pause
    The sequence is as follows
    Takes water in
    Takes water in short burst
    Runs empty cycle
    Dryer motor runs
    All bottom row of lights flash fast
    Thanks for you continued help
    #381031
    Those lights are not used for error codes, the dryer ntc can cause all sorts of weird faults on these machines .
    #381032
    taichibob
    So the fault lights are the wash cycle progress lights
    Not sure why heater motor runs
    Bob
    #381033
    Most of us are not sure how they manage to work in the first place. :rolls:
    Basically low end, Indesit made appliances. 🙁
