hoptpoint ctd80 condenser dryer error code f10
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hoptpoint ctd80 condenser dryer error code f10
  • #29253
    AASWALES
    hi the machine comes up with error code f10 i tested the thermostats ontop of the heater 2 were faulty i replaced them and then it flashed f13
    any ideas
    thanks alan
    #222488
    Re: hoptpoint ctd80 condenser dryer error code f10
    Its in the Known Error codes thread, page #4. F13= rear NTC open or short circuit. Some have two stats plus NTC some just one stat and NTC. You should always replace the lot and make sure the condensor is clear.
    hotpnt
    have you replaced the NTC with a stat by mistake??
    #222490
    AASWALES
    there is 3 in the back but iv not come across this machine before what is a ntc will it come in a thermostat kit i tested all and one is ok the other 2 are gone is that the ntc thats ok
    #222491
    If the thermistor is white and flat then you need kit number 1703607. If the thermistor is black and has a small raised hump you need 1703608.
    AASWALES
    yeah its black with lump thanks very much alan
