Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Horpoint Dryer TVFS73BGG.9(UK) stopping and sometimes starting
- This topic has 8 replies, 3 voices, and was last updated 1 year, 5 months ago by
duncanbbd.
October 8, 2024 at 2:39 pm #103007
duncanbbd
ParticipantThe tumble drier stutters after a minute or two. sometimes it starts and stops an few seconds later. more often than not it just tries to start but stops
Unsure what the problem is.I originally changed the motor capacitor. Then I decide to get Hoptpoint support out to fix it but when the heard I had changed the capasitor they walked away.
I didn’t want to dumpt the drier as I thought it would be simple to fix.
I changed a thermistor, sensor at the output air flow. I just changed the motor too, seemed to work better but next day it is back to stuttering. (I’ll be selling a new motor :o) )
I got a local service man out and he changed some diodes on the main board.
I think its heat related as when I disconnect the heater it runs without issue, though not drying.
anyone any ideas.October 8, 2024 at 5:46 pm #491458electrofix
Moderatorare you sure its not your socket thats faulty and failing under load
October 8, 2024 at 10:26 pm #491459duncanbbd
Participantthanks, it’s worth considering. initial guess is don’t think so.
thinking is it runs quite welll without stopping, but maybe as you suggest the load on the heating element.the heating element itself could be faulty ?
BrianOctober 8, 2024 at 11:18 pm #491460electrofix
Moderatorno cant be the element the way you describe it
element either work or not normally and if it failed in use it would continue with no heat or throw up a fault code
October 11, 2024 at 4:23 pm #491461duncanbbd
Participantwhen running I hear some clicking. when it tries to start.
this video shows whats happening.
https://2mx.co.uk/pdf/VID_20241011_171034.mp4wonder if the relays are needing cleaned or replaced ?
thanks again.October 11, 2024 at 8:39 pm #491462electrofix
Moderatorok when it stops does it come up with and sequence of lights
if not it does sound like a board fault as it cant hold in the relays. you can see the flashes as the heater and motor kick in but it cant hold it
A lot of Hotpoint board can only be fitted by an engineer with programming equipment
October 11, 2024 at 9:20 pm #491463kaibart
ModeratorI’ve had this before it’s a board fault
October 14, 2024 at 11:07 am #491464duncanbbd
Participantthanks for rhe advice about the board fault.
there is no lights on the panle.kind of makes it pointless then getting a new board ?
looks like I’ll be moving to a non-hotpoint tumble drier as its so expensive and the drier is only 5 years old.October 14, 2024 at 11:10 am #491465electrofix
Moderatoryou better off away from hotpoint anyway as build quality has not been there for years
Avoid Hoover as well, terrible access for repairDave
