Horrible BF41!
  • This topic has 3 replies, 4 voices, and was last updated 17 years ago by Kez.
  • #44827
    Kez
    Hi – have fitted a metering tank to this delight however the dishwasher is now leaking from the bottom corners of the door. Have received and fitted a new door seal kit 1801570 (which appears to be modified) but has made little difference. Is there anything I should know about this model / door seal?? Many thanks!
    #282503
    loopey
    Re: Horrible BF41!
    Iff its got a plastic lower wash arm see iff the ends have split at the seem
    Had this a few times now… replace arm with the metal type one .. 🙂
    phil
    #282504
    Re: Horrible BF41!
    31×9985 is what you need, still plastic (never seen a metal version) split is often in the centre and not at all aparent before the hight pressure water is pumped though it.
    #282505
    burns
    Re: Horrible BF41!
    Ive had a few of these over the years and replaced the bottom spray arm. last time though it didnt last that long before it split again. On that occasion I went round it with an old soldering iron and melted the seams and tidied it up a bit with emery. Its still working and that was a couple of years back (lasted better than the original).
    Hey its only a bodge if it doesnt work 😉
