Hot/cold tap enquiries
  • #102306
    Froggy8
    hi guys
    hope everyone is OK.
    I have had this washing machine for a year and it keeps using all our hot water. I have had a look behind it and it is plugged into the hot water supply. The question is can I change it to cold tap supply at all?
    Many thanks guys
    #488278
    if it has one hose it should only be on a cold supply
    Froggy8
    Many thanks for the quick reply.
    Where we are renting, landlord has lent us his washing machine, it was all set up for us to use. I just thought it was meant to be like that.
    I will change it to cold tap when I get home.
    Many thanks again, we will have hot water now.
    #488280
    Froggy8
    The washing machine in question is the beko wm74155lw, will check to see if it really does have only one hose.
    #488281
    Froggy8
    i have took some pictures of the hose:
    https://i.postimg.cc/K8LNvd4R/20231010-190826.jpg
    https://i.postimg.cc/zfrkL0Rp/20231010-190831.jpg
    i am guessing that it does not matter if it shows a red hose?
    what i mean is that there is a red ring on the hose.
    #488282
    nope
    one hose means cold feed
    2 hoses and you have to make sure hot and cold correctly placed
    as a test
    select just a rinse. That should be cold, if its hot its wrong
    hot rinses and not only will you waste energy but you would have one heck of a time ironing what comes out
