Hot fill dishwasher
Home Forums General Trade Forum Hot fill dishwasher
  • #68693
    bzz67
    Hi, anyone know of any hot fill only new dishwashers?
    got a customer asking for one. cant find any???
    thanks
    #372449
    Re: Hot fill dishwasher
    Read the many related topics (below this post) if I were you.
    (by the way, most BSH dishwashers will be fine on hot fill provided the incomming doesn’t exceed 60 degs C.):wink:
    #372450
    don
    An old thread here may be useful 😉
    Don
    #372451
    The new ISE one can do hot fill, built for it actually because of the systems they use in Sweden.
    ben–nevis
    As with a lot of Manufacturers De Dietrich and Fagor machines can connect to hot water up to 60 degrees.
    It is worth bearing in mind that if ANY brand machine uses a cold inlet to aid the condenser drying this will be affected by using hot water, also any cold rinses will also use hot water, so unless the customer has solar / heat pump, it is not always the best option
