Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hot or Cold Feed Supply?
- This topic has 7 replies, 5 voices, and was last updated 17 years, 9 months ago by
richardc1983.
June 24, 2008 at 3:36 am #37591
richardc1983
ParticipantGetting my first dishwasher tmrw. was thinking of using the hot feed from the washer to supply it as my washer only uses the hot feed when it is doing a boil wash which is never as i dont ever do a boil wash. Obviously its one less thing to have to do when connecting it up as the hot feed pipe is already connected, To ensure the dishwasher got hot water i was going to run the hot tap first to ensure that water was hot, this is just next to the kitchen sink and is table top version to on my worktop.
Question is, would you recoomend to connect to hot or cold, manufacter says it would be ok to connect to hot fill but they recomend cold fill. Not sure why really as a dishwasher benefits from having the water hot straight away.
So what do you reckon? Reasons as to your choice too i like to have an explanation to back up my choice.
June 24, 2008 at 7:22 am #255737kwatt
KeymasterRe: Hot or Cold Feed Supply?
Hi Richard,
Not advisable.
The detergents you use are designed to work on a temperature curve and they won’t work correctly if you use hot water.
If the machine has a side fill chamber you’re wasting your time as the water is stored in that before it goes into the wash cavity and will lose heat.
The fill levels are so low that the water you run off will be less than the machine needs, very wasteful and costly if you’re on a water meter.
If you use tablets they won’t dissolve properly and this can and, probably will, lead to overfoamng on rinse and any fault/damage may not be covered by your warranty.
It’s cheaper to heat the water in the machine than to boil a kettle of water.
There’s probably more but that’ll do for starters to illustrate why it’s not a good plan.
HTH
June 24, 2008 at 7:47 am #255738richardc1983
ParticipantRe: Hot or Cold Feed Supply?
I havent got a warranty anyway as the model is 3yrs old and im buying it as 2nd hand but apparently its hardly been used.
Fingers crossed it works (its a bosch table top, the model SKT 5002) some people mention that the wash pump may be seized if it isnt used regulary? 😕
June 24, 2008 at 7:49 am #255739dom999
it may also damage the internal water softener
June 24, 2008 at 7:56 am #255740don
ModeratorRe: Hot or Cold Feed Supply?
This is a good article K wrote a while ago all about dishwasher supplies etc.
Don
Keep your dishwasher smelling nice, use thisYou can buy your dishwasher freshener hereJune 24, 2008 at 7:57 am #255741kwatt
Richard, that’s even worse!
A table top will fill with about a litre or so of water and you are going to run off how many litres just to save a few minutes and reduce performance? The savings in electricity are, at best, minimal.
Sorry, but it’s absolutely pointless doing this IMO.
June 24, 2008 at 10:18 am #255742iadom
richardc1983 wrote:my washer only uses the hot feed when it is doing a boil wash which is never as i dont ever do a boil wash.
Perhaps you should. 😉 hot wash
June 24, 2008 at 6:03 pm #255743richardc1983
Ok ok lol i will connect to the cold feed, it heats the water within about 10mins anyway! No worries guys thanks 🙂
