Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hot Point Fridge Freezer FFM70A unable to run compressor
- This topic has 8 replies, 5 voices, and was last updated 8 years, 7 months ago by
mik23.
September 2, 2017 at 6:31 pm #92057
mik23
ParticipantHi All,
I am currently suffering from this problem.
Compressor is unable to start specially in high temp out side i-e hot weather.
I tried to open the box in attached to check the compressor relay but unable to do so.
what i hear is a humming sound then a click and then nothing happens.
I am unable to open this blackbox with the compressor and dont want to break it.
I have looked at the compressor 1 page guide but didnt really explain how to open this box.
p.s. I have defrosted the freezer section
cheers
September 2, 2017 at 7:19 pm #450157kwatt
KeymasterRe: Hot Point Fridge Freezer FFM70A unable to run compressor
That buzz (hum), click is the overload doing its thing which is protecting it from being a danger.
The compressor is either overheating to the point where it could be considered dangerous and the safety is doing exactly as it should to prevent risk.
Or, the compressor has had it.
September 3, 2017 at 3:08 am #450158mik23
ParticipantRe: Hot Point Fridge Freezer FFM70A unable to run compressor
Thanks K
i was trying to open that junction box to check the relay inside.
The compressor is not running for what ever reason so I was looking how to check this.
September 3, 2017 at 7:06 am #4501591totalshambles
Via your picture that white cylindrical shaped thing is a 4uf capactor (?), they are cheap at about 5 quid and it COULD BE that that is the problem. Under the compressors black plastic cover, if you can unclip it, there is not, from memory, a relay in the old sense of the word as such, as it has ptc starting. There were 2 compessors used as far as known: one is a danfoss and the other is an Embraco make ( more expensive ptc part and probably a near 50 quid worth of fleecing ). The ptcs are different. If you are lucky the capactor might repair it if unlucky the ptc will fix it, if really suffering horrendously from bad luck the compressor is nuked. I`d be trying that capacitor first. Power off before tatting about with it is of course a must.
September 3, 2017 at 8:48 am #450160mik23
Do you mean that i cant acces the plastic junction box ?
I dont know how to access this otherwise give that a try.
Capacitor may be an issue will check.
September 3, 2017 at 9:16 pm #450161SAMURI
As Ken said if it buzzes then makes a clicking noise the compressor is faulty as it is drawing to much power or seized.
This would not be a DIY repair.
If you get a problem with the start capacitor klixon then you would not get the buzzing noise before the click.
So I would not waste your time and money trying to fix it.
Bob
September 4, 2017 at 8:17 am #450162mik23
Cheers Gents much appreciated
I have uploaded the video what is exactly happening
https://www.dropbox.com/s/rtzzelee8pirj … 2.mp4?dl=0
thoughtsSeptember 4, 2017 at 2:47 pm #450163mik23
Gents,
I closed the fridge for 4 hrs nothing happened and its working now.
Not sure what is wrong
September 12, 2017 at 7:44 am #450164freezerdungonebroked
I can sympathise with you, mick, I thought I might have to access the relay in the same fridge myself and that box just was not designed to be accessed!
As you’re discussing the FFM70A, I was hoping someone might be able to take a look at my question please? I’m on the verge of buying a new fridge and it would be a shame if it turned out just be be a fuse!
http://www.ukwhitegoods.co.uk/forumsphpbb3/post452300.html
Thanks!
