Hot point FTCF87BGG F03 FAULT
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hot point FTCF87BGG F03 FAULT
  • #92624
    jonbenj
    Hi Folks
    I have a 15 month old Hot point FTCF87BGG dryer that has recently been giving F03 fault codes. A quick search suggests this may be the front thermistor. Is this likely to be easily accessible to enable me to test? And is it available as a spare part as I haven’t found one online yet? Any hints tips and other suggestions most gratefully received. Gutted that its bust as this machine was bought at a subsidised rate to replace one of the “faulty” ones that had performed faultlessly for 3 years. Go figure.
    #451743
    Re: Hot point FTCF87BGG F03 FAULT
    Part number is C00291937.
    Access is not at all easy, located into the large plastic drum front support duct assembly.
    Not had any recent calls to this fault but there have been quite a few questions regarding F03 on the forum recently. ๐Ÿ™
    #451744
    jonbenj
    Think I’ve found it thanks. left hand side panel off looking from the front. Screwed into the bottom of the front panel below the drum. I’ve dusted off my multimeter. What sort of figure should I be looking for at room temperature, and I guess also need to test it when hot?
    #451745
    TBH ntc’s as a rule are quite reliable, unlike a washing machine there is very little vibration inside a dryer to loosen or break wiring connections which are more often the cause of similar faults on washers.
    It would be interesting to know if the ntc has actually failed all the same.
    #451746
    jonbenj
    With my meter set a 2k I’m getting .356
    I chucked in a low oven, about 90 degrees, for 5 minutes and got .320
    Then I tried it in the freezer for 5 mins and got .356
    Not very scientific but it looks like its knackered.
    It doesn’t look as though i can order it from the ukwhitegoods shop, but it’s available elsewhere.
    #451747
    Drop them a line to spares@ukwhitegoods.co.uk I’m sure they will be able to help you out. ๐Ÿ˜‰
    #451748
    jonbenj
    Cheers iadom, Iโ€™ll let you know how I get on.
    #451749
    jonbenj
    Ordered the part from here on Friday, slightly dearer than Fleabay, received yesterday afternoon, fitted last night, jobs a good un.
    Relatively straightforward if any one else wants a go!
    Unplug from the mains, remove 2 screws from the lid and slide back/unclip to get it off. 4 screws down the rear of the left hand panel (thatโ€™s left hand looking from the front!)
    One screw at the left hand front top then release side panel.
    Unclip wiring from bottom then remove two screws holding thermistor in place. Carefully remove wiring connection from thermistor.
    Reverse to refit.
    Fiddliest bit was re screwing thermistor in place. A magnetic tipped screwdriver would have been handy.
    Thanks again to iamdom for the assistance.
    #451750
    Thank you for the update. ๐Ÿ™‚
