Hi can anyone help,
Fridge model # BL11.Intergrated larder fridge.Recently there has been a thick build up of ice at the top/back of the fridge.
The Hinges seemed a little worn as the door level had dropped slightly so I replaced these thinking the door seal was not lining up correctly.
Now the fridge door is in the right position seal seems fine , the light is on the compressor is running but only the top 10-15cm of the cooling plate seems to be cold and is once again building up ice.The rest is warm.
Please if anyone can help it would be much appreciated.
