Re: Hot Point no power.
CROSSBONES wrote:Ok, so where is the inspection panel?
The bottom front panel!
CROSSBONES wrote:what do I look for?
What indeed?…..you need tools and test meters and the knowledge of electrical appliances to procede beyond this point. From your description as to what went wrong, I have no idea? I would start from this point though OK?
Tell us more, what do you reckon?….We can probably help?…..But if you get stuck then you try for a local engineer to check it out for you via the link below. 😉
