Hot point WMA76
  • #86315
    Matthewvl
    The washing machine – Hotpoint WMA 76 will not drain water during the cycle.
    Fills, spins ok.
    When it gets to draining, the water just sits there. If I lay the outflow pipe down in a shallow bucket the water will drain out this way, but the machine makes no attempt to activly drain it. I seem to remember hearing a noise previously when it was draining water, is this some pump? Anyway the machine is silent when it should be emptying.
    Thanks in advance.
    #430791
    Andy jones
    Re: Hot point WMA76
    Pump is probably blocked. Access from the back panel
