Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › HOTP WDL / WML TRIPPING RCD ON SPIN
- This topic has 9 replies, 4 voices, and was last updated 15 years ago by
DAGAV.
March 18, 2011 at 9:37 am #61724
DAGAV
ParticipantMorning,
Can anyone help me with A HOTP WML / WDL machines various models and factories where the appliance trips the electrics on the final spin.
Insulation resistance checks done and are infinity ( or there abouts) on every machine I have seen (there have been a few now).
Tech bulletin from Merloni states: check motor brushes and armature for any signs of damage and if these are ok change the settings file for the new file version which correctly activates the half field to avoid damage to the motor. Sometimes it is possible this fault can cause damage to the module and a new module will need fitting also.
Have changed the settings file, job bounced!! (motor fine) fitted motor and changed settings file, job bounced. fitted module, motor and changed settings file, job bounced.
Any other ideas ❓ Does anyone now what is causing the rcd to trip on these machines:?:
(checked customers socket and run machine in different socket, appliance is located indoors in a utility room and is not damp, no leaks from the tub and only trips on last few mins of spin when ramps to full speed)March 18, 2011 at 1:54 pm #347374Martin
ParticipantRe: HOTP WDL / WML TRIPPING RCD ON SPIN
A model number would help. Are we talking single or 3 phase motors here? 😕
March 18, 2011 at 2:33 pm #347375DAGAV
ParticipantRe: HOTP WML TRIPPING RCD ON SPIN
Single phase motor and accross the range of WML machines and various Indesit too (I stand corrected, not WDL range of machines).
Models listed below:
Hotpoint : WMD740PUK.RA,
WMF760AUK.R , WMF760GUK.R, WMF760PUK.R
WMF740PUK.R, WMF740KUK.R, WMF740AUK.R, WMF560PUK.R , WMF540PUK.RA ,
WML760PUK.R, WML730PUK.RA, WML730GUK.R, WML560GUK.R, WML560PUK.R,WML540PUK.RA
HV7L145PUK, HV7L145GUK, HV6L105PUK, HV5L125PUK
Indesit: IWE7145SUK, IWE7145KUK,
IWD7145UK, IWD7145SUK, IWD7145KUK, IWD7145BUK, IWD6125UK, IWD5123UK
IWC6165UK, IWC6165SUK, IWC6153UK, IWC6145UK, IWC6145SUK, IWC6125UK
IWB6123UK, IWB5123UK,March 18, 2011 at 2:39 pm #347376Martin
I can only guess then that the high speed lead on the wiring harness is damaged and shorting to earth? Have you double checked the state of the wiring harness? 😕
March 18, 2011 at 2:47 pm #347377DAGAV
I’ve done that, it’s not just me that is having this problem but many of my colleagues too. I am seeing 1-2 a week with the same problem so have checked various parts and wiring.
i have spoken to Indesit and they update the settings file but this has not help as descibed in my previous post.
I was wondering if any Indesit Company guys on here that would know what causes this?March 18, 2011 at 5:58 pm #347378HotDog
the motors are more likly to be the culprit the replacment ceset motor is better than origanal motor with yellow label marked ACC
March 18, 2011 at 10:50 pm #347379iadom
ModeratorRe: HOTP WDL / WML TRIPPING RCD ON SPIN
DAGAV has already changed the motor on this one Cliff. 😉
March 23, 2011 at 9:46 am #347380DAGAV
Yep motor changed, the motor on these machines are ceset.
April 1, 2011 at 10:37 am #347381DAGAV
Anyone got anymore info or can help?????
April 1, 2011 at 2:49 pm #347382Martin
Spiky mains filter maybe?
