Hotpint Condenser Dryer TC71 Cutting Out after a 10 seconds
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpint Condenser Dryer TC71 Cutting Out after a 10 seconds
  • #6996
    jenicks
    Can anyone help please.
    Hotpint Condenser Tumble Dryer TC71 keeps Cutting Out after a few seconds (5 – 20 seconds). It’s been fine since new( 1 year old) but now cuts out. If I press the start button it starts fine for about 5 – 20 seconds then stops or sometimes If I press the start button and hold it in it starts, but if I release my finger off the button it stops. I suspect some sort of thermal cutout problem maybe?? but I’m not sure where to look or what to look for to replace! From cold it’ll run for about 30 seconds before stopping.
    The machine itself is all clean……filter’s clean, condenser cartridge is clean, water collector is empty. I have removed the side panels and given it a good vacuum inside.
    Anything else ermm….It blows hot as normal. It’s been on most of the day, but that’s not unusual, it’s been fine.
    I’m quite capable of replacing the faulty component it’s just knowing what is at fault. Motor, switch, etc.
    Any help would be most appreciated. Thank you.
    #120821
    Simon46
    Re: Hotpint Condenser Dryer TC71 Cutting Out after a 10 seco
    The fault on this unit is the relay that holds the dryer on until the door is opened or the power is turned off. Labelled Schrack. If you wish to take a look remove the Mains plug from the socket first.
    #120822
    jenicks
    Simon46 wrote:The fault on this unit is the relay that holds the dryer on until the door is opened or the power is turned off. Labelled Schrack. If you wish to take a look remove the Mains plug from the socket first.
    Thanks Simon, I saw that relay when I took the lid off for a look. How certain are you 50/50 or 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}+ sure. Are you talking from experience.
    Your input has been most appreciated.
    Would it be the item listed below:
    Hotpoint Relay – HPT1701157
    Description:
    Fits:
    Hotpoint
    T601CW, T602CW, TC11P, TC71N, TC71P, TC71X, TC72N, TC72P, TC72X, TD41, TD46
    Details:
    Type: 65.31
    FINDER
    START RELAY
    1 Pack of 1 Item
    Price: £17.30 £20.33 Including VAT at 17.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    Thank you
    #120823
    Dave_Conway
    It’s 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain to be that jenicks.
    Yes, that’s the one on easyfix, it’s also available in our own shop here:
    http://shop.ukwhitegoods.co.uk/1701157- … ryer-relay
    A bit cheaper as well but no picture yet 😉
    #120824
    jenicks
    Thanks Simon and Dave.
    I’ve just ordered one from ukwhitegoods as per the link above.
    All the best 😉
    David
    #120825
    Dave_Conway
    Got the order thanks.
    I’ll send it 1st class (you just caught our last despatch run) and hopefully it will arrive tomorrow as you asked, but I won’t guarantee it being late in the day and the time of year 😉
    #120826
    jenicks
    Dave, you are a star.
    Have a great weekend my friend.
    All the best
    David
    #120827
    Simon46
    Dont forget label or make a note of which wires go where, after pulling the mains plug of course!
    #120828
    I also have the same problem but have a ‘Crusader’ (no model number) condensing tumble dryer. This is a chepo dryer but the unserviceable relay that was in it was a Schrack RM505730. Could you tell me if the Whitegoods link above will be the same one? Only, after looking at the second link provided, the picture had the contacts in a different configuration. Please can you email me at: dusty911@hotmail.com
    I will also keep on checking the site just in case.
    Many thanks,
    Jason
    #120829
    Jason
    Crusader is a name used by Hotpoint/Creda, so the relay will be one of theirs. The model number is normally on the control panel, on a label around the door opening and on a label on the back.
    I regret we won’t be able to give you an exact part number/price etc without it.
    wellyboot
    Hi guys,
    sorry to hi-jack the topic, but I also have the same problem – this time with a Creda condenser dryer (not got the exact model) but it seems to be the same part: Schrock RM505730 with details….230v/16a 400v 1hp
    Did an internet search – found this q&a with the same problem, brill 😀 , but now can’t find the part in your e-shop
    Please don’t tell me you don’t stock it any more? 🙄
    Lee.
    #120831
    Dave_Conway
    Yes we do, it’s here 😀
    http://shop.ukwhitegoods.co.uk/Tumble+D … Relay.html
    #120832
    Matblack
    Is it possible to confirm if the link provided above still points at a suitable replacement for the Schrack RM505730?
    I have a Hotpoint TDC30 which has the same cutting out problem detailed above and which we have had to operate by holding the button in with gaffer tape, which is neither safe nor ideal 🙁
    Thanks in advance
    MB
    #120833
    Yep, thats the one. 🙂
