Hi, evap fan is only running intermittently, i have changed green and yellow thermistors, and run a test procedure with no fault codes showing. condensor clean and condensor fan running ok, evap fan runs fine with a lead on it. any ideas ?? Tim
is the fridge door operating the light switch correctly, they have a habit of moving the center hinge when the fridge door is loaded too heavy and the switch just somtimes fails to catch the top of the door.
